AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
2d Section/Elevation - Model Space View boundary
2 REPLIES 2
nnatev
576 Views, 2 Replies
Is the model space view boundary a type of Xclip fuction for 2d Section/Elevation drawings? if so how do you activate it? As you can see in the image attached the boundary is there but the linework outside the box is still visible. Any ideas?
2 REPLIES 2
KathyMoffa
in reply to: nnatev
With the Properties Palette open, select the Bldg Elevation Line.  On Design/Dimensions, change Use model extents to No, and you can change the Height and Lower extension.
in reply to: KathyMoffa
so awesome thank you for this question and answer!
”Boost
