the program will hang on draw and modify commands. I thought it was the MAGNET option for osnap, but that is off. It happens on almost all draw commands (circle, rectangle, line) and some modify commands (mirror), but not on move or copy. Anyone else having this issue?
I turned off the Hardware Acceleration and that did not help; made the pointer movement spotty as if the snap mode was on. It seems that the more entities the drawings has the more the commands hangs. When starting out a new drawing, there is no issue with drawing a line or rectangle. However, going into an existing drawing where there are hundreds of entities, the program hangs as if it is searching entities for a point to start. With MAGNET turned on, it would search for the nearest entitiy, but it shouldn't with it turn off.
I'm using the program on Windows 7 in Parallels Desktop on a Mac OS X (10.7.5) with 16 gb memory.
I have found that drawing in the Model Space tab works just fine for all drawings. The problem comes up with working in any tab such as WORK-RCP or WORK-FLR. When working within the viewports the issue of hanging comes about; it has to do with the viewports. Working in Paper Space on these tabs is just fine...once I switch it to Model Space within the viewports is starts to have issues.
