I have reinstalled the program and now have the menu bar. I have tried to turn on the classic tool bar the way auto cad suggested and nothing happens. How do you set to classic autocad workspace?
Solved by pendean. Go to Solution.
There is no classic workspace in AutoCAD Architecture 2011.
Are you sure you did not install an ACA2010 alternative classic menu before the reinstall?
Well that answers that question. I now know how I turned off the menu bar and was because I was looking for a way to turn on the calssic view. I clicked on the QAT and then clicked to get out. I did get out but it also turned off the menu bar. How can turn it back on without reinstalling autocad?
MENUBAR command, set it to 1.
You can also set the Ribbon to not be so all consuming of screen real-estate by tapping that little arrow button at the end of the ribbon tabs.
