AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
redc52
226 Views, 2 Replies
2007-2015
Does anyone have suggestions for getting up to speed from 2007 Autocad Architecture?
to 2015?
thanks
2 REPLIES 2
David_W_Koch
in reply to: redc52
You could check out the new feature articles in my blog, links to which can be found in this article.  Many others have written about new features in both ACA and AutoCAD; Google should be able to help you find those articles.
Most of the ACA changes since the 2007 release have been incremental.  The big interface change will be getting used to the ribbon.  Toolbars and the pull-down menus have been dropped from the ACA.cuix, but tool palettes are still used extensively.  You will want to read up on annotative content, added to AutoCAD (along with the ability to set a drawing scale for the model tab and for viewports on the layout tabs).  ACA content had drawing scale/annotative content prior to AutoCAD (but mostly affecting scale at time of placement); the ACA content has extended that previous functionality by incorporating the AutoCAD annotative feature but keeping the annotation plot size.
The ability to edit Wall Cleanups in place was added, and then refined, during that time.  Column Grids were enhanced.  Grip edit capabilities for both AEC and AutoCAD objects has been greatly enhanced.  The Center/Offset options when placing Doors and Windows were split into separate options and then reunited.  Grouping and subtotals were added to Schedule Tables.  You can use Layer Keys in Display Settings.  3D AutoCAD objects and the editing therof has been greatly improved.
The above are just a few items that came to mind as I was typing this.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
redc52
in reply to: David_W_Koch
Thanks very much.
I started looking at some tutorials and looks more user friendly for sure.
I always changed my dimstyle in the pulldown when dimensioning and texting
when the details called for different scales.
I never utilized the section tool and have always drawn my own under the
elevations
Layers are how I manipulate my printing tabs and draw everything in model
space.
I'm sure I'll find some better ideas and shortcuts.
Robert D. Evans
L+R Architectural Design
Construction Management
21 Governor Bradford Road
Brewster, MA 02631
redc52@gmail.com
508.691.2022 mobile
508.632.2421 fax
”Boost
