Hi @Richard.Vivanco,
Thank you for posting your question here.
As far as I can tell, I don't believe there's a way to select multiple profiles at once during the Add a Ring process. It might make a good feature request though.
This functionality did exist in the UK Content tools that for some reason AutoDESK stopped supporting in 2012. I have asked AutoDESK to revive these tools as they are brilliant and also include custom windows and walls etc. They never came back to me.
I have to say I do find the behaviour of AutoDESK odd at times as I am led to believe that they no longer want to support ACA in turn pushing REVIT hence not continuing with these tools and yet on other threads on this forum they are actively asking us for development ideas.
The beauty of AutoCAD verticals is the reliance on the AutoCAD base, which is customizable. While the aec addon commands make scripting needlessly complicated by not accepting multiple command calls, this workaround should allow you to create a profile with nested rings in fewer steps. Just save the following to a trusted support folder and use (load "dcbprof"). Then use dcbprof to create the profile rather than "ConvertLineworkToProfileDef". I'm not sure how much work it would save unless you do this a lot or unless you autoload the program.
Doug,
One thing I have noticed is that your prompts are not displaying correctly. We only get "select objects" displayed for both selection options.
Kind regards
Ben
Make your command line larger or look above the command line for the prompt. I can't make the at cursor prompts work because AutoCAD only uses the last prompt which in this case is coming from ssget itself.
