AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Dimstyle Problems?
9 REPLIES 9
Message 1 of 10
Jason_S
459 Views, 9 Replies
Dimstyle Problems?
I have a couple projects that the Dimstyle changes the Text Movement from Move text, no leader to Move text, add leader. I can't figure out why this changes and was hoping someone here could help out.
We place a bunch of dimensions and some we move out from between the witness lines and draw an arc to the dimension text. Save and close the drawing and when we open it the dimensions we move and drew an arc to now have the leader and the drawn arc.
We highlight all instances and go to the properties palette and change the setting and all looks good while in the file. Close and reopen they go back. What is up? Getting old fast.
Looked at the DimStyle all looks good. Changed the Dimstyle to an OOTB dimstyle and it still happens.
Confused and frustrated.
Thanks for the help
9 REPLIES 9
Message 2 of 10
in reply to: Jason_S
see attached
Message 3 of 10
Jason_S
TeamSquid,
I can't seem to open or dowload the file.
Message 4 of 10
Dimstyle -> Modify -> Fit tab -> Text Placement: Over dimension line, without leader.
Message 5 of 10
Jason_S
OH...That is what I have been changing but is doesn't stay that way. I exit the drawing and come back in and it changes back to Dimension line with leader. I was wondering if there is a system variable that will lock this. Doesn't matter what Dimstyle either.
Message 6 of 10
DIMTMOVE sysvar?
wrote in message news:6069905@discussion.autodesk.com...
Message 7 of 10
Jason_S
Well I have that set to 2 for the DIMTMOVE. Nothing.
Message 8 of 10
David_W_Koch
Do you have any customizations (Startup Suite in the APPLOAD dialog, ACADDOC.lsp file, some other method) that run every time you open a file, that attempt to enforce a standard? Could that customization be defining an office-standard Dimension Style, that happens to have the same name as the one you use, but that has "leaders on" for moved text?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 9 of 10
Jason_S
David,
I looked all through the acad2008doc.lsp and compared it to the one on my computer and they are the same. This only seems to happen on a couple computers.
Message 10 of 10
A3Collaborative
Was there ever a fix for this problem?
We're having the exact same problem in Architecture 2010.
”Boost
