AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD Architecture 2014 - 3D Printing
4 REPLIES 4
JASONSTREET7385
616 Views, 4 Replies
I've designed an object using 3D poly, but cannot it to a .stl file since it is not a solid.
Is there a way to convert a 3D poly to a solid, or is there an easier way to create odd shaped 3D items.
This is in an effort to print the item on the MakerBot Replicator Z18.
Thanks for your time.
4 REPLIES 4
Maybe post a picture of the object so we could comment on how to create it...
EXPERT ELITE MEMBER
I've attached the file (I hope).
It is a corner stone on a bridge pier where the vertical face transitions to the nose panel.
I traced the two 'ends' of your 3d polyline and then used the LOFT command to create a solid.
EXPERT ELITE MEMBER
Thank you MarySeufert!
I was unfamilair with the LOFT command.
In my attempt I had the "ends" ni place and couldn't connect them, now I can!
This I believe will be the solution to my conundrums!
The file was able to export to an .stl, so tomorrow I will test it and try and print it.
Thank you again for your time.
”Boost
