AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCad 2014 Fatal Error unhandled 80000003h exception 1230478ah
11 REPLIES 11
Message 1 of 12
6338 Views, 11 Replies
Within a minute or two of running the program I recieve the below error message, and the program shuts down.
AutoCad 2014 student version Fatal Error unhandled 80000003h  exception 1230478ah
Can anyone help?
11 REPLIES 11
Message 2 of 12
Soyoung.H
First of all, I need to explain about the fatal error message.
Fatal error occurs in many different reasons.
And usually, fatal error message indicates there was a conflict at certain sector of your hard drive.
So just a message itself is not the magic key for the resolution.
Let me address you for general factors of fatal error, first.
1. Lack of memoryWhen you don't have enough RAM, you may get this error.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2862058&linkID=9240617
2. Invalid drawingThe drawing file may be damaged during your work process.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18809891&linkID=9240617
If you get fatal error regularly, you need to check when it occurs.
For example, "when" some specific program is running together,
"when" you execute some commands, "when" you work with some files..
It helps to find out what causes the problem.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Soyoung.H
Message 3 of 12
pendean
What is your OS?
PC specs?
Did you turn off your antivirus before installing ACA2014?
Do you have any other programs running?
Do you have any devices or phone plugged into your PC/laptop?
Is the crash triggered by a command or do you just start the program and it crashes in its own?
Message 4 of 12
pendean
As a student you can also ask/post here:
https://autodesk.zendesk.com/anonymous_requests/new
Message 5 of 12
My OS is Windows 8, and I didn't realize I had to turn off my anti viris during install.  At first I thought the error was due to a drawing, but I ran the program on it's own and it still shut down within two minutes.
Message 6 of 12
calfcreek_2
in reply to: pendean
Hey Dean, we're having this issue as well.
The crash comes just as project browser is opening up all of the files. Sometimes it loads all of the files but then immediately if you move the mouse or anything it crashes.
I don't think the anti-virus was disabled when installing on these machines. My question is, will turning off the anti-virus and running a 'Repair' work? Or...should we do a clean install?
Thanks for your help.
Signed,
Dufus who didn't read instructions...LOL
Message 7 of 12
calfcreek_2
in reply to: calfcreek_2
Doh!!
It was hardware acceleration in our case. Turned it off and it has worked fine since. Old issue we should have known.
It is about time that AutoCad addressed this once and for all though isn't it? Jus' say'n.
Thanks everyone!
Keith D. Rodebush
RA
Message 8 of 12
calfcreek_2
Well, I spoke too soon. The issue has returned on two of the three machines.
CER_88224974 This is the error report number from my last crash.
In our case it always happens when project browser is loading files.
We really need a solution to this. With the inability to save back in any way without disabling AEC content tools; going back to a working Cad program is not an option.
Any help will be greatly appreciated.
Keith D. Rodebush
RA
Message 9 of 12
calfcreek_2
Autodesk has suggested a new NVidia driver. I have installed it and will get back with the results...
Keith D. Rodebush
RA
Message 10 of 12
calfcreek_2
Seemed to work better for a while, but then returned.
Tried several suggestions from this forum, none seem to be a permanent fix.
Keith D. Rodebush
RA
Message 11 of 12
calfcreek_2
in reply to: Soyoung.H
Mine comes when I use Project Browser to select the project and it loads the Project Navigator files. Within 3-5 seconds after it crashes.
Thanks for any input.
Keith D. Rodebush
RA
Message 12 of 12
calfcreek_2
We have unchecked the box to have Project Browser load at start-up. Thus far with three different work stations and 10-15 start-ups we have not had a crash. Pray for us....:-)
Keith D. Rodebush
RA
”Boost
