I have tried a few different setting to get a PDF emailed to myself
Every time I am getting a blank pdf missing layers or just a single square on the pdf
what am i doing wrong?
I am working with a ipad pro
Solved by tonydommer. Go to Solution.
Here are the option I have. I am not sure what they refer to.
I select Export
then plot
"Export to PDF"
-plot style
- Grayscale.ctb
- None
-Layout
- Model
- Layout 1
- Layout 2
-Papersize
- I have been selecting ISO A4
- Orientation
- Landscape
- Fit to Paper selected yes
- Scale 1:1
- 1mm = 1 unit
Scale and the 1mm are not selectable with fit to paper selected
Paper Six
plot style none
layout model
paper size ISO A4
plot area extents
landscape oreintation
fit to paper
still no layers and the image is just a box not the floorplan I trying to send?
i moved my file from Dropbox to a folder on the a360 acct i think. but once i moved it i was able to forward it.
the resolution wasn't as good as i expected, any thoughts as to why it might not be that great when i zoom in?
We are having he same issue with students printing or plotting on the Ipad. It will cut off dimension lines and some times even part of the project. We are drawing I have tried almost every different combo when trying to print to get this not to happen. If you choose different option it plots the project really small.
hello! did you know about google drive sink and did this app have pc version?
How would I make one layer bolder than the other when printing. I am working on the most recent version of a mac in AUTOCAD 2020
