Revcloud arc length set by drawing type or dynamic revclouds
I work with AutoCAD to create REVCLOUDS for different drawing files with multiple viewports with different scales and I am constantly having to change the revcloud arc length for each different scale I am using. May I suggest that the revcloud arc length be set for each individual drawing, the same way Units can be set by drawing type? I often use 0.3 as arc length in one drawing and then have to use 1.2 in a separate file. I should be able to set the length to 0.3 in one file and 1.2 in another. Currently, I have to keep a cheat sheet for the arc lengths I need depending on the file I am in. Perhaps the revclouds could be dynamic?
I hope you consider my suggestion.
Thanks, Nick
”Boost
