I use ZE for (command "Zoom" "E") and ZW (Command "Zoom" "w") for some shortcuts. In 2015, after I run the ZE command and type in ZW at the command prompt it says "unknown command", then if I type it again it works. I can type ZW after that again and continue to Zoom window all day long but as soon as I Zoom Extents and then type ZW again (or just Z for that matter) I always get a "Unknown Command" error the first time. Does anyone know why this is happening? 2014 works fine.
Thanks in advance.
John
Solved by johnw. Go to Solution.
I can't repeat that here on 2015, but just use Z and then define a window, no need to use ZW and then define a window.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
