AutoCAD Forum
Zoom extents jogs
2 REPLIES 2
tbennett
219 Views, 2 Replies
Zoom extents jogs
I've had this periodically through several releases of AutoCAD: when in paperspace, I zoom extents, AutoCAD will zoom extents then shift a little left.  If I zoom extents again it will go further left.
It used to be that if I just closed the file and reopened it would go away, but one of my coworkers can't get rid of the problem.  Any ideas?
Please mark "Accept as Solution" if your question is answered. Kudos gladly accepted.
2 REPLIES 2
pendean
in reply to: tbennett
Can't replicate buy it is curious that restarting AutoCAD stops the issue from occurring.
christina.davis
Hi Todd,
Can you please create a video that shows this behavior? I am trying to grasp how much of a shift. I have seen cases where there is a shift when first opening the file as  the program fills up the ribbon and adjusts for docked palettes, etc., but not the progressive shifting like you mention with each zoom extents.
Also, can you please tell us more information about your installation: AutoCAD Version? Service packs installed? Operating system?
Try :
https://screencast.autodesk.com/
OR
http://www.techsmith.com/jing.html
Thanks 🙂
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
Autodesk, Inc.
”Boost
