I've had this periodically through several releases of AutoCAD: when in paperspace, I zoom extents, AutoCAD will zoom extents then shift a little left. If I zoom extents again it will go further left.
It used to be that if I just closed the file and reopened it would go away, but one of my coworkers can't get rid of the problem. Any ideas?
Hi Todd,
Can you please create a video that shows this behavior? I am trying to grasp how much of a shift. I have seen cases where there is a shift when first opening the file as the program fills up the ribbon and adjusts for docked palettes, etc., but not the progressive shifting like you mention with each zoom extents.
Also, can you please tell us more information about your installation: AutoCAD Version? Service packs installed? Operating system?
Try :
https://screencast.autodesk.com/
OR
http://www.techsmith.com/jing.html
Thanks 🙂
