AutoCAD 2013/2014/2015
GrantsPirate
Message 11 of 21 (90 Views)
Re: XREFS SCALING
07-16-2014 12:12 PM in reply to: jest2525
There is no way you can assume any emotion from the words in my response, (hint: there wasn't any) just a simple statement of fact and truly interested in why you asked a question you knew the answer to.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
CADEngr2014
Message 12 of 21 (90 Views)
Re: XREFS SCALING
07-16-2014 12:32 PM in reply to: jonpage
Jon,
Thanks for that thought;  The only thing that has changed since this started to occur, is my coordinate units were changed from US Survey Feet to International Feet, the coordinate remained the same.  I do not imagine that should cause this type of problem, but it is a difference of units, as you mentioned.
Distinguished Contributor
jest2525
Message 13 of 21 (87 Views)
Re: XREFS SCALING
07-16-2014 12:38 PM in reply to: GrantsPirate
I'm not arrogant enough to assume there is only one answer.  That's why the question was asked.
And yes, words and the assemblage of them into a statement can evoke emotion (even if you said there was none).  That's what I read... but then that's just me.
Thanks for your insight though. :smileyhappy:
Employee
jonpage
Message 14 of 21 (80 Views)
Re: XREFS SCALING
07-16-2014 01:15 PM in reply to: jest2525
Since you changed the units on the location units of one of the drawings, it would scale if you used the option "Locate using Geographic Data".  That could also have scaled the xref.
I don't think there is a problem asking why even when you know the answer.  My answer might differ from your answer.  It helps others searching for similar questions, but not posting.
Hope this helps,
Jon
Jon Page
AutoCAD Interaction Designer
drjohn
Message 15 of 21 (73 Views)
Re: XREFS SCALING
07-16-2014 01:31 PM in reply to: jest2525
jest2525 wrote:
Calm down dude.  Why you so angry?  Not a reaction I'd expect from an "Expert Elite".
To answer your question... why does anybody ask?  To learn... even at my ripe old age.  I never once said "Do it my way as it is the only way!"  I'm just curious what other needs may be.  Is that ok?
Jeez!
Careful here ... your burning a very valuable resource.
Assume no emotion unless it is delivered (eg: :smileymad: or :heart:  or :smileyfrustrated: ) visually.
If you want to see condescending, read a few of pendean's posts and then read GrantsPirate's posts.  Notice the difference.
Just  FYI  :smileyhappy:
DJ
jest2525
Message 16 of 21 (58 Views)
Re: XREFS SCALING
07-16-2014 02:58 PM in reply to: drjohn
I've been known to be a valuable resourse too.  I worked for what today is considered the largest engineering company in the world for almost 2 decades.  Though I left them almost 9 years ago, they still call me when they have CAD issues.  So you see, I do know a bit about what I do... and am still willing to learn by asking seemingly dumb questions.
All in all though, banter is good if it teaches someone something.  Right?
CADEngr2014
Message 17 of 21 (47 Views)
Re: XREFS SCALING
07-17-2014 04:43 AM in reply to: jonpage
JonPage,
We are using unitless drawing files, and setting INSUNITS=2 seems to be the only setting that resloves the scaling issue.  In our Drawing Units dialog, we have Type set to Decimal, Insertion Scale set to "Unitless" which has always been the case as far as I remember.  However, since we are using "unitless" insertion scale units, why shouldn't we be using INSUNITS=0?
CADEngr2014
Message 18 of 21 (41 Views)
Re: XREFS SCALING
07-17-2014 05:04 AM in reply to: CADEngr2014
JonPage,
Ok, I found the problem.  We are set-up to use unitless files and INSUNITS=0.  However, in one of my refeence files, I found the units were set to feet.  So the system will scale the referenced file by a factor of 12 to bring it into a file that is set to unitless.  Not usre if there is a way to cause a files units to change to feet from unitless, without explicitly toggling the change?
Employee
jonpage
Message 19 of 21 (35 Views)
Re: XREFS SCALING
07-17-2014 08:59 AM in reply to: CADEngr2014
Jon Page
Employee
jonpage
Message 20 of 21 (34 Views)
Re: XREFS SCALING
07-17-2014 09:04 AM in reply to: jonpage
Well I guess I need to stop using IE for this forum... previewed and all text disappeared.  :smileyfrustrated:
@CADEngr2014
I'm assuming you are running plain AutoCAD.  There are three places that you can change the INSUNITS of the drawing.
INSUNITS sysvar at command line
Drawing Units dialog - UNITS command
Geographic Location dialog - GEOGRAPHICLOCATION command
Other versions of AutoCAD like AutoCAD Architecture have additional ways to specify units.
Jon Page
