AutoCAD 2013/2014/2015
Member
ndunn28
Message 1 of 10 (903 Views)
Wipeout Lines Not coming to Front when printing
903 Views, 9 Replies
01-10-2013 05:57 PM
when printing in view ports, wipeouts don't show. wipeouts are transparant.
ive tried copying the same wipeout lineweights and pasting it in new documents but have no problems there. i've tried resaving under a brand new document but still no luck. apparently it's only happening in the same 2 documents.
anyone have problems with this before?
*Expert Elite*
M_Hensley
Message 2 of 10 (888 Views)
Re: Wipeout Lines Not coming to Front when printing
01-11-2013 04:23 AM in reply to: ndunn28
I don't quite get what you mean because wipeouts are supposed to not plot. Thats sort of their thing.
The wipeout frames have the option to plot or not. Check your frame option. Also see if it is on a non plotting layer, or the old "plot paper space last" setting in the plot dialog.
*Expert Elite*
pendean
Message 3 of 10 (868 Views)
01-11-2013 10:14 AM in reply to: ndunn28
Do you mean they don't hide anything? Did youn turn on LINEMERGE in the PC3 file you are using by chance?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
ndunn28
Message 4 of 10 (832 Views)
01-15-2013 06:07 PM in reply to: ndunn28
Hi There I meant to say that the lines behind the wipeout comes to front and you can see the lines through the wipeout blocks. Get what I mean? I attached a PDF to the forum post to show what I meant. thanks Regards, Nicole Dunn NICOLEHOLLIS nicole dunn 935 natoma street san francisco california 94103 d 415 430 9826 t 415 278 9457 f 415 278 9458 ndunn@nicolehollis.com www.nicolehollis.comCONFIDENTIALITY NOTICE: The information contained in this email and any attachments may be privileged and confidential information, intended only for the use of the individual or entity named above. It is the recipients responsibility to scan this email and any attachments for viruses. If you are not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this email communication is strictly prohibited. If you have received this email in error please notify NICOLEHOLLIS, Inc. immediately either via reply email or at 415 278 9457 and delete this email. Thank you for your cooperation.
*Expert Elite*
M_Hensley
Message 5 of 10 (826 Views)
01-16-2013 04:04 AM in reply to: ndunn28
AutoCAD does not always follow its draw order properly. Often I have select everything except the wipeouts then right-click and pick send to back. Then I select the wipeouts and pick bring to front.
Also if the wipeouts are in model space and any other objects are in paper space make sure "plot paper space last" is not checked in the plot dialog box.
Member
alee
Message 6 of 10 (792 Views)
02-06-2013 10:23 AM in reply to: ndunn28
have you found the solution?
I have same issues with 2013 autocad, it works fine with 2012 though.
cec
Active Member
cec
Message 7 of 10 (770 Views)
02-07-2013 06:57 AM in reply to: alee
No not yet, but I'll let you know. We just upgraded to 2013 too so it sounds like were in the same boat. Mike
Member
alee
Message 8 of 10 (766 Views)
02-07-2013 09:24 AM in reply to: cec
Thanks Mike, I'll keep digging as well. Aaron
*Expert Elite*
dbroad
Message 9 of 10 (763 Views)
02-07-2013 09:30 AM in reply to: ndunn28
Sometimes editing drawings that contain wipeouts can inadvertently affect the draw order.  Just select the wipeout, right click, choose drawing order, and bring to front.  You can alternatively choose the linework that should be hidden and then use draworder to "send to back"
If the wipeout is in a dynamic block, you may need to reset the block and then adjust to get the new definition to take.
If the wipeout is in an xref attachment, you may need to select the xattachment and choose drawing order for that object.
Member
alee
Message 10 of 10 (760 Views)
02-07-2013 09:55 AM in reply to: dbroad
Hi, Thanks for the input. We always make sure that wipeouts are at the front, so we know that it's not the layer order that's creating this issue. If we set our merge control to 'lines overwrite' under plotter configuration, it will make the wipeout to show properly on PDF, however, if we choose this option, We have to make sure all the layers to be in correct order which is really time consuming. Also, We didn't have any issue with 2012 where we have merge control set to lines merge. We are using 'DWG to PDF - PDF ePlot - by autodesk' for plotting pdf. (same plotter used for 2012) wonder if this needs updates to suite 2013. Please let me know if you had similar experience in the past and found a solution. Thank you~
Announcements
Need installation help?
