Hello
Why won't AutoCad recognise the 3/4 (three quarter) symbol from the Windows symbol pallette when inserted into attribute text, it displays a question mark?
Any ideas how to show a ¾ symbol in attribute text?
Thanks in advance for your help.
Solved by dontaylor2. Go to Solution.
Solved by 3wood. Go to Solution.
You can change the font used in the attribute to one of TureType fonts such as Arial.
Then ATTSYNC the block.
Hello there and thank you for the solution.
i have added simplex.ttf to windows 7 fonts which allows me to use the ¾ symbol.
Thanks again.....
