AutoCAD is giving me wierd coordinates in "List" Can someone explain this to me?
Constant width 0'-0.0000"
area 0.0000 square in. (0.000000 square ft.)
length 1605'-9.4183"
at point X=2396348'-0.1200" Y=245925'-0.2400" Z=0'-0.0000"
at point X=2.8737E+07 Y=245878'-5.6400" Z=0'-0.0000"
Exponential (scientific) notation.
X=2.8737E+07 = 28,737,000
Typical for very large or very small numbers.
What is "weird" about the y coordinate?
With such large numbers, do you really need decimal inch units (especially to 4 decimal places)?
Is there a logical need to work a long ways away from 0,0,0 (maybe you can move when finished if needed)?
Well, it is an old CAD file from a contractor. It is of some fee mineral outlines in Lafourche. If you want to run it, here is a bit of the file. I did load the scientific into Excel to compare points. As you can see, they are points that are WAY out there. Atttached is a screen dump of how it comes into ArcGIS and how it is in AutoCAD 3D Map (the blue outlines.)
Open
area 486630016.5384 square in. (3379375.114850 square ft.)
length 11345'-2.5057"
at point X=2.8721E+07 Y=247672'-0.2400" Z=0'-0.0000"
at point X=2.8721E+07 Y=247671'-8.2800" Z=0'-0.0000"
at point X=2393424'-0.1200" Y=247665'-5.4000" Z=0'-0.0000"
at point X=2393410'-1.0800" Y=247659'-2.6400" Z=0'-0.0000"
at point X=2393390'-2.7600" Y=247648'-10.5600" Z=0'-0.0000"
at point X=2393372'-6.0000" Y=247630'-6.9600" Z=0'-0.0000"
at point X=2.8720E+07 Y=247608'-3.7200" Z=0'-0.0000"
at point X=2393341'-1.3200" Y=247590'-0.3600" Z=0'-0.0000"
at point X=2393331'-4.3200" Y=247573'-10.3200" Z=0'-0.0000"
at point X=2393329'-9.0000" Y=247549'-9.9600" Z=0'-0.0000"
at point X=2.8720E+07 Y=247535'-11.8800" Z=0'-0.0000"
at point X=2393348'-1.2000" Y=247530'-1.5600" Z=0'-0.0000"
at point X=2393354'-3.6000" Y=247518'-2.6400" Z=0'-0.0000"
at point X=2393358'-8.2800" Y=247494'-3.4800" Z=0'-0.0000"
at point X=2393359'-0.2400" Y=247474'-3.3600" Z=0'-0.0000"
at point X=2393369'-9.7200" Y=247426'-5.2800" Z=0'-0.0000"
at point X=2.8721E+07 Y=247420'-7.6800" Z=0'-0.0000"
at point X=2393394'-0.3600" Y=247414'-10.0800" Z=0'-0.0000"
at point X=2393404'-3.2400" Y=247401'-0.1200" Z=0'-0.0000"
at point X=2393412'-6.8400" Y=247383'-1.6800" Z=0'-0.0000"
at point X=2393419'-2.0400" Y=247347'-2.7600" Z=0'-0.0000"
at point X=2393423'-9.0000" Y=247311'-3.4800" Z=0'-0.0000"
at point X=2393424'-2.5200" Y=247283'-3.4800" Z=0'-0.0000"
at point X=2393430'-6.1200" Y=247265'-4.6800" Z=0'-0.0000"
at point X=2393456'-9.2400" Y=247251'-9.8400" Z=0'-0.0000"
as JDMATHER already told you, that is normal for such big (geographical) coordinates.
What you can do to get the list or coordinates with larger values in front of the decimal sign is to reduce the number of digits behind the decimal separator: so start command _UNITS, and for the length==>precision set the number of decimal places to less than 4 (which is your current setting).
HTH, - alfred -
