AutoCAD 2013/2014/2015
6 Kudos
Post 1 of 11
Accepted Solution
Width factor of multiline attribute
2456 Views, 10 Replies
04-28-2013 11:41 PM
I was trying to find out, how to change the width factor of multiline attribute and I failed.
The only way was to change the width factor of texstyle the attribute uses.
Is there a way to override this property for a single attribute? And if not, is there some reason for that?
Here is a quick rough routine (without error checking), that can help you:
(defun c:CH_ATTR_WIDTH ( / new_width atent atent_list)
(setq new_width (getreal "\nEnter new width factor: "))
(setq atent (car (nentsel "\nSelect multiline attribute to change width factor: ")))
(setq atent_list (entget atent))
(setq atent_list (subst (cons 41 new_width) (assoc 41 atent_list) atent_list ))
(entmod atent_list)
(princ)
How it works:
Command: CH_ATTR_WIDTH
Enter new width factor: .8
Command:
Maxim
*Expert Elite*
1,210 Kudos
Post 2 of 11
Re: Width factor of multiline attribute
04-30-2013 12:57 PM in reply to: matus.brlit
What should happen when running command _ATTSYNC?
Personal opinion: If you do individual character formatting within a text (MTEXT) you will end in having a chance to just change the textstyle to update all texts (and that what text-styles are built for, to just change e.g. a font at one position (the style) to have it done for the whole document).
At least I don't like to do individually character-settings/overwrites within an MTEXT as of that reason.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
6 Kudos
Post 3 of 11
05-01-2013 01:46 AM in reply to: Alfred.NESWADBA
I think you misunderstood me, I don't want to change width factor of individual characters, I want to change the width factor of the whole text.
The same you can do with single-line attributes, so I'm not worried about ATTSYNC.
Also you can change the width factor of attributes in inserted block using the dialog, but for multiline attributes, the textbox is disabled.
16 Kudos
Post 4 of 11
05-01-2013 07:16 AM in reply to: matus.brlit
Here is what i use to adjust the width of the text box for Mutliline Attributes.
Some client title blocks have Multilines Atts that are FIELDS and run over the borders...
I wish that there was a way to use a lisp or script where you select the Multiline Attribute and then set the width of the text box.
Here's the manual way:
Use the EDIT ATTRIBUTES dialog box with the ATTEDIT command or ATE alias
Click the "ellipsis" button (button with 3 dots next to the Attribute that you want to adjust
Drag the 2 arrows in the upper right of the text box window to adjust
Exit out of the dialog box by clicking OK...
~Greg
6 Kudos
Post 5 of 11
05-01-2013 11:19 PM in reply to: greg.battin
Thanks Greg, but this is not what I am looking for. You can get the same result by inserting linefeed where you want the next line.
Imagine the rectangle, where you have a 2-line attribute. You can't add a new line to reduce the width, because you are also limited by the height of 2 lines.
This is how it looks for single-line attributes
I would like to be able to esit the width factor for multi-line attributes, too.
*Expert Elite*
532 Kudos
Post 6 of 11
05-02-2013 02:35 AM in reply to: matus.brlit
(entmod atent_list)
(princ)
How it works:
Command:
Maxim
Architect
MARSS
MacACAD | MARSS
6 Kudos
Post 7 of 11
05-02-2013 02:52 AM in reply to: maxim_k
great solution, thanks Maxim
16 Kudos
Post 8 of 11
05-02-2013 07:05 AM in reply to: matus.brlit
Ah - I see
Thanks for clarifying.
Cool solution Maxim_k
~Greg
Valued Mentor
2 Kudos
Post 9 of 11
05-02-2013 01:15 PM in reply to: matus.brlit
If I understand the question, you could make a textstyle and set the width factor there.   When you make the attribute, assign it that textstyle.  If you need to change the width factor of all the attributes you can change it globally in the textstyle then do an attribute sync.  If you want to change just one or a few attributes you can do it in the attribute editor under the text option tab.  It worked for me in 2013.
Please don't forget the "accept the solution" button if this helps.  Thanks
Valued Mentor
2 Kudos
Post 10 of 11
05-02-2013 01:22 PM in reply to: mbuonocore
My bad, you said multiline attribute, my response works directly for single line attributes.  It also works for multiline att's with an extra step.  You can still have the attribute read the textstyle with the width factor set.  However the width factor is only apparent if the text box is expanded as in the other responses.
Post to the Community
New Post
