AutoCAD Forum
WHERE IS MY VP COLOR ON LAYER MANAGER
10 REPLIES 10
Message 1 of 11
485 Views, 10 Replies
On Layer Manager can't see VP Color and VP Linetype see picture can same one help Thank.
10 REPLIES 10
Message 2 of 11
pendean
Right-click at the headers bar and turn them on.
Message 3 of 11
maxim_k
Are you in Layout?
If so, right click on layers table caption and verify that these controls are enabled.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 11
in reply to: pendean
Not working see picture
Message 5 of 11
nestly2
in reply to: maxim_k
@maxim_k wrote:
Are you in Layout?
What Maxim said.  VP overrides only apply to the active Layout/Viewport, so make sure you're on a layout tab.  Additionally, remember that VP overrides are controlled indivually for each PaperSpace Layout, as well as each viewport inside the layout.
Message 6 of 11
jggerth
You may want to try posting in the Mechanical group -- that's not a standard vanilla Acad layermanger you are showing.
Message 7 of 11
in reply to: jggerth
Can you tell me where is the  "layers table caption"
Message 8 of 11
pendean
Message 9 of 11
jggerth
iit's nice to be quoted....
Message 10 of 11
pendean
I should have used the proper method of quotation but it's not available in the Quick Reply: it was good info of course.
Message 11 of 11
GrantsPirate
The command AMLAYER is called when using the ribbon, tool palette, etc.  Change it to .LAYER.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
”Boost
