Can someone direct me on how or where I can get the Detail tools that was in the 2013 Tool Palette?
Batt insulation
drywall
Plywood
studs
pretty much everything you need to build a detail.
Where are these tools?
I can't say I've ever seen those tools in AutoCAD.
Go back to into your 2013 Tool Palette, right click on one of the tools, and select Properties to find the source dwg.
Are we talking about AutoCAD, or AutoCAD Architectural?
This is in Architectural package.
In 2013 Architecture, If you pull up the Tool Paletts, it comes up under the Design tools.
If you right click on the right side of the Palette you will get a pop up with options.
Down toward the bottom you can select "Detailing"
This will give you a differnent tool palette set of tabs.
Basic
Exterior
Roofing
Dors & Windows
Interiors
Finishes
Each one of these tabs has blocks you can insert for all your detailing needs.
From Batt Insulation, Mortar joints, Drywall that you can draw out in the desired thickness you need and it is hatched.
Wood studs, Mtl Stunds,
Everything you would want for working out details.
These tools are not in 2014 that I can find.
If someone can tell me where these are or how I can get this implemeted in 2014, would greatly appreciate it.
Might get better answe4rs in the Architecture forum,
http://forums.autodesk.com/t5/AutoCAD-Architecture/bd-p/248
since that's not in the vanilla offering
