I swear there was a setting iether in the sheet set publish settings or the optiosn menu somwhere that allowed the following...
"Don't Reopen drawings that are already open when publishing"
This obviously saves a lot of load time when publishing/plotting.
Anyone know where this is?
Kapanther
Solved by ceethreedee.com. Go to Solution.
Boom!! found it.. I cant believe how obvious it was. It's in the publish dialog box.. Which im so used to skipping because i plot straight from the sheet set!
This speeds up plotting so much if you already have all the drawings open, untick to force open drawings to be plotted without reloading.
From the sheet set manager just use the "publish dialog box" option as per image below
Be good if it was a native option in the sheet set publish settings though!
