AutoCAD Forum
What is the difference between template: "Tutorial-mArch.dwg" and "acad.dwg"
2 REPLIES 2
chikito1990
989 Views, 2 Replies
Dear all,
What is the difference in terms of position of an inserted blocks origin(X, Y) and the dimentions of the drawing itself. Because I noticed that when I export the elements I have some different origins than the one I have in the plain template?
What role is the frame playing in the picture? How it changes it?
I already tried to make some research but I did not find anything.
Best regards,
Dimitar Georgiev
2 REPLIES 2
pendean
in reply to: chikito1990
The first is for use with a tutorial, the latter is the default template everyone uses.
chikito1990
in reply to: pendean
Dear pendean,
Thank you for the reply. But how is the template affecting the block coordinates. Because when I make DataExtraction the coordinates are lets say (400,400) and when I remove the frame and make DataExtraction again the coordinates are lets say (120,120). So I was wondering how the frame is affecting the drawing?
Best regards,
Dimitar Georgiev
”Boost
