AutoCAD 2013/2014/2015
JamaL9722060
Message 1 of 11 (611 Views)
Accepted Solution
What distinction is between “intersection” and “apparent intersection” in snaps,
611 Views, 10 Replies
09-15-2012 03:54 AM
I’m not sure what difference is between the “intersection” and “apparent intersection” in snaps.
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
does this video show you the missing link?
- alfred -
*Expert Elite*
dbroad
Message 2 of 11 (602 Views)
Re: What distinction is between “intersection” and “apparent intersection” in sn
09-15-2012 05:29 AM in reply to: JamaL9722060
The 3rd dimension.  In order to intersect, lines must share a common plane.  This stuff is in the help files BTW.
JamaL9722060
Message 3 of 11 (590 Views)
09-15-2012 01:17 PM in reply to: dbroad
thanks for the answer.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
stevev0983
Message 4 of 11 (584 Views)
09-15-2012 04:42 PM in reply to: JamaL9722060
Apparent intersection absolutely does not have to have a 3rd dimension involved. Intersection is typically used when 2 lines do in fact touch and form an intersection. Apparent intersection is the point where 2 lines that do not touch, would touch if you extended them (assuming they are not parallel, of course). In your drawing, there is currently no intersection between the bottom blue line going to the center of the circle and the blue arc in the upper left. If you tried to draw a line from the intersection of that line and that arc, it would say there is no intersection. But if you tried to draw a line from the Apparent Intersection of that line and that arc, it would start at a point where the line would intersect the arc if you extended the line all the way to the arc. Try it. Draw a line from the Apparent Intersection of that line and that arc and you will see what you get. It's a fantastic o-snap and you will be amazed how much you will end up using it.
JamaL9722060
Message 5 of 11 (569 Views)
09-16-2012 09:18 AM in reply to: stevev0983
thank you very much for the elaboration.
i couldn't draw a line for the "apperent intersection" on the arc to the line.
i couldn't know what to type on "appoint of and"
and thus i couldn't feel how to get the benifit of the "apperent intersection"
best
Jamal
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
Alfred.NESWADBA
Message 6 of 11 (565 Views)
09-16-2012 10:16 AM in reply to: JamaL9722060
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
JamaL9722060
Message 7 of 11 (561 Views)
09-16-2012 11:41 AM in reply to: Alfred.NESWADBA
Many thanks for the contribution Alfred. I got it now. The video does help capturing the idea fast.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
dbroad
Message 8 of 11 (546 Views)
09-16-2012 04:04 PM in reply to: stevev0983
@Steve:
Intersection snap also works when objects do not touch as well but will not work when the objects are not on the same plane.  If an intersection is not found on the first pick, it is deferred, (3 dots).  Only APP will find an apparent intersection between non-coplanar objects. The trouble with leaving APP on is when you have accidental non-coplanar objects, it won't tell you the objects aren't coplanar.  So you can end up creating a mess accidentally.
JamaL9722060
Message 9 of 11 (496 Views)
09-17-2012 12:39 PM in reply to: dbroad
Thank you for the help Steve. This point is quite important.
All the best
Jamal
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
dbroad
Message 10 of 11 (481 Views)
09-18-2012 06:09 AM in reply to: JamaL9722060
You're welcome.  Apparently the question needed asking.
Doug
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
