Is it possible to overlap viewports and make the content of the front viewport overlap the vp frame of the other?
Like below?
good point, I also have not got the frame of the viewport hidden by the "upper" viewport.
The chance I see is that you clip the viewport that should be in the background around the upper viewport.
Look to the attached drawing and find info about command _VPCLIP >>>here<<<.
HTH; - alfred -
Yeah clipping is the only way.. It jsut annoying to manage. Everytime you want to move the other viewports you ahve to move the clip as well..
put your viewport boundary to a (unprint) layer.
if you need to display your boundary.....just draft one by yourself.
