Hi
Why visual style changes when I hit qsave?
Is there a way to stop that?
Solved by Bertievz. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
I guess (as no suggestions arrived yet) that nobody can reproduce that.
So please give us some input that brings us to the situation to see what you get.
Every single info might bring us closer to the source of the problem!
- alfred -
I encountered the same thing and was able to fix it in my drawing. The culprit is 'Sky Background and Illumination'. Once it is switched on (SKYSTATUS=2), that drawing always reverts back to perspective view and 3d wireframe when you quicksave, even if you changed back to 2D wireframe.
To fix the drawing, set SKYSTATUS to 1 first ('Sky Background') and then to 0 ('Sky Off'). It seems that you can't switch directly from SKYSTATUS = 2 to SKYSTATUS = 0. Then you can change to 2d Wireframe and save.
In order to use sky again you have to first switch back to perspective view.
I am having the same problem. I followed your instructions w/ SKYSTATUS but it won't let me change from 1 to 0 (it stays at 1). Not sure what the problem is.
I had the same problem and this solution worked for me.
AutoCAD 2014
Windows 7
