AutoCAD 2013/2014/2015
New Member
fewltu
Message 1 of 9 (1,626 Views)
Visibility States all screwed up
1626 Views, 8 Replies
04-03-2012 08:51 AM
I work with a lot of blocks that use visibility states. I've immediately found that editing these in 2013 is impossible because of a bug. When I'm on "Visibility State 1"and select "Visibility State 2" from the drop down, the state just reverts back to "Visibility State 1". The actual block will change and my drawing from "State 2" will show up, but the drop down still lists "State 1". So, when I try to Make Visible an object (in order to put it on "State 2" which is currently visible on my screen), the object is put on "State 1". This needs fixed IMMEDIATELY. This makes Autocad 2013 worthless to my firm. Going back to the old version...
rkmcswain
Message 2 of 9 (1,624 Views)
Re: Visibility States all screwed up
04-03-2012 09:00 AM in reply to: fewltu
FWIW.....I was able to replicate this problem.
vladimir.michl
Message 3 of 9 (1,585 Views)
04-03-2012 10:08 AM in reply to: rkmcswain
Yes, confirming this bug. Needs to be fixed.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Valued Contributor
Dave_S
Message 4 of 9 (1,556 Views)
04-03-2012 01:46 PM in reply to: rkmcswain
I have many dynamic blocks with 2 or more visibility states and so far they seem to work ok for me. Thes blocks were created in version 2011 plain jane AutoCAD.
I admit creating new blocks in 2013 with visibility states is a bit of a challenge with a sticky state list box, but i managed to do it. You just have to fight with the arrow keys and the mouse button. But I understand they are fixing this.
Distinguished Contributor
Exmateria
Message 5 of 9 (1,520 Views)
04-04-2012 06:23 AM in reply to: fewltu
Yeap.... annoying bug.
Product Support
Volker_C
Message 6 of 9 (1,447 Views)
04-18-2012 06:01 PM in reply to: fewltu
I wanted to let you know that Autodesk is aware of this behavior and we are working towards a long term resolution. A work around at this time is to turn off the system variable PropertyPreview.
Command:  PROPERTYPREVIEW
Enter new value for PROPERTYPREVIEW <ON>: OFF
Best regards,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
New Member
BeatsUsingAnEraser
Message 7 of 9 (1,355 Views)
05-18-2012 12:16 PM in reply to: Volker_C
I also have visibility state problem - block works as a test block but not in drawing.
felt33
Message 8 of 9 (1,333 Views)
05-21-2012 09:38 AM in reply to: Volker_C
Works ok for a work around. Although I hope it's fixed soon. I don't understand why, if it worked before, was it changed?
New Member
baxsilver
Message 9 of 9 (628 Views)
05-20-2013 01:24 PM in reply to: fewltu
Try select the state with arrows and enter. Works to me.
