AutoCAD Forum
Viewports not displaying (ACAD Architecture 2015)
6 REPLIES 6
wlajemian
1809 Views, 6 Replies
I have a problem with my viewports not displaying and disappearing when trying to copy them, sycronize them, and create new ones.
When I create new ones, existing viewports disappear, leaving just the viewport frame. I cannot edit them, or activate them. However when I select them, it shows up as viewports in properties. Also I have drawn them on separate layers dedicated to my viewports. They are not on Defpoints layers.
The other odd thing is the viewports plot correctly and show up correctly in print preview.
I have a brand new computer workstation with the latest Nvidia Quadro graphics card and 32 GB of RAM.
this problem happens for one particular file. when I open a new drawing from our template or another drawing the problem does not occur. I am holding off on doing a wblock at last resort.
See attahced images.
6 REPLIES 6
jcampbell924
in reply to: wlajemian
Check your "MAXACTVP" system variable.  This variable is stored per DWG.
Gary_J_Orr
A quick thought... (I have not actually downloaded your drawings)...
Due to the fact that it seems to be localized to a single drawing try the
MAXACTVP drawing variable
-Gary
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
wlajemian
in reply to: Gary_J_Orr
Thank you that solved it. How does one know all the system variables? It's mind boggling.
jcampbell924
The fastest way to look through them is to use the Express Tools System Variable tool.
Jeff Campbell
Senior Applications Specilist
Burns & McDonnell
Gary_J_Orr
For me it's a matter of 17 years of experience... running into things like this, searching help (and later the communities) for what could be causing such a problem, etc...
-G
Gary J. Orr
TFOSTERMORPHIS
Hello All,
I have a tab in which the viewport border is not showing,
What is the setting for  MAXACTVP between 2 & 64?
See attached jpeg file..
The viewport border is at the tip of the yellow arrow but does not show.
Tommy
”Boost
