Hello
I seem to have lost the grips on my viewport.
Maxactvp set to 64
Viewport is on a layer that is unlocked.
Is there a system variable that I may be missing as it only seems to be happening to me and not my collegues.
Screenshot below of the selected example viewport - as you can see the layer it is on is unlocked.
Solved by MatthewB80097. Go to Solution.
This appeared to be something with an AutoCAD bolt on software, as when I changed the profile over back to standard CAD it appeared to work fine.
I have tried to reset and create a new Profile in AutoCAD 2018 and still unable to get that grip @MatthewB80097, could you please help?
