I have problem in one outside drawing in my office. in layout there are many vieport but vieport border line not appear.
I make all layer ON and unfreez and unlock also viewport border not shown.
is there any option. please co operate.
thanking you
Solved by nestly2. Go to Solution.
Layers can be controlled independantly for Modelspace and Paperspace. Make certain the viewport layer is not OFF/Frozen while in Paperspace on the Layout tab.
i make all layer ON and unfreez, also viewport border not appear , and even when i delete all from layout , viewport not delete
Is the viewport clipped? If the original clipping object has been deleted the viewport will still exist but not be visible
Just double checking if the Layer is completely unfrozen.
If none of the suggestions work. maybe zip the files and attach so we can view it.
thank u very very much
there is defpoint layer which is VP Freeze as per you shown.
so i make unfreez, after that all view port border appear.
thanks a lot
thanks again
@salimulla wrote:thank u very very much
thanks a lot
thanks again
Glad to help
Whoever created the drawing probably put Viewports on Defpoints so the viewports won't plot, but I would recommend moving the Viewports to thier own layer so their display and plot settings can be controlled independently.
