AutoCAD 2013/2014/2015
Active Member
bouwenb
Message 1 of 12 (4,865 Views)
Accepted Solution
VIEWBASE - inventor server failed to load
4865 Views, 11 Replies
10-23-2013 11:44 PM
Hi all,
when I try to use the VIEWBASE command to create views from my 3D solids, I always get the message "inventor server failed to load" and the command stops. I am using AutoCAD 2014 with SP1 installed on windows 8 .
In a similar message in the 2010/2011/2012 discussion group:
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/viewbase/td-p/3316345
it is suggested to reinstall the software, but this is not working for me.
I have already tried to 'repair', 'reinstall' and completely remove all the software and then reinstalling it, but nothing seems to fix this problem.
Are there any other programs I need to have installed to get this command to work?
Does anyone have a solution to fix this problem?
Any ideas on where to look for the cause of this error?
Many thanks.
I have the same problem.
BUT I fix it very simple. If you use win 8.1 - 64 bit
You must go at "Autodesk AutoCAD Services & Support"  and "Updates & Service Packs", you can fiind this at: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618
After you must DOWNLOAD and REPLACE the file from "Model Documentation Hotfix for 64-bit Windows 8.1" that you can find at: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22443084&linkID=9240618
You must make the steps from "read me" file.
Theo.
emaenda
Message 2 of 12 (4,837 Views)
Re: VIEWBASE - inventor server failed to load
10-25-2013 01:38 AM in reply to: bouwenb
You are not alone in that. I am currently downloading Autodesk Inventor 2014 Service pack 1. I am running Building Design Suite Ultimate 2014 on Windows 8.1. but Inventor fails to launch, thats why I downloaded  sp1 If it works...Oh well..
New Member
babgr
Message 3 of 12 (4,732 Views)
11-10-2013 10:15 PM in reply to: bouwenb
Theo.
Active Member
bouwenb
Message 4 of 12 (4,702 Views)
11-12-2013 11:00 PM in reply to: babgr
This solved the problem, everything works fine now.
Thanks!
New Member
sillwwia
Message 5 of 12 (2,530 Views)
05-07-2014 03:51 AM in reply to: bouwenb
hi i have same problem but in autocad 2012 mechanical... where is no hotfix for that version.
i buy that program and its really sad to know that i cant fix it.. plz help
fhof
Message 6 of 12 (2,521 Views)
05-07-2014 06:00 AM in reply to: sillwwia
I think Viewbase was introduced in AutoCAD 2012, but you were locked to only being able to detail one object per drawing (i.e. fairly unusable). The Viewbase command has seen a lot of improvement since then. The most stable version so far has been in AutoCAD 2015, for what it's worth.
New Member
mjeyaraj2012
Message 7 of 12 (1,546 Views)
08-01-2014 10:10 PM in reply to: babgr
Thank so much
New Member
bubblykorea
Message 8 of 12 (1,374 Views)
08-25-2014 08:27 AM in reply to: babgr
Hello.
I'm using Autocad 2013 and Window 8.1.
I have the same problem with others.
Command: VIEWBASE
Inventor Server failed to load.
I installed AutoCAD 2013 Service Pack 2, but it doesn't work for me.
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2013-service-...
Is there other service pack? Anybody can help me, please?
Active Member
bouwenb
Message 9 of 12 (1,366 Views)
08-25-2014 11:05 PM in reply to: bubblykorea
See the solution suggested by babgr, but now look for the AutoCAD 2013 Model Documentation Hotfix for Windows 8.1.
You can find it here.
Regards.
New Member
bubblykorea
Message 10 of 12 (1,342 Views)
08-27-2014 07:06 AM in reply to: bouwenb
Thanks,bouwenb. It works now!!!!
Have a nice day~    :smileyhappy:
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
