AutoCAD Forum
View setup...UCS not following?
4 REPLIES 4
BMATT
532 Views, 4 Replies
Ok, back again - I have my views set up (basically I rotate my drawing 90, 180, 270 and back to 0).  When I choose my named view, the drawing turns nicely - but the UCS does not.  So when I am working on the new view the horizontal and vertical construction lines are backwards - this is quite frustrating.
I used to just change the UCS with the good old manual 'Z' pick, which worked perfectly, but I am trying to simplify my life (a tiny bit) and just pick the named view - can I set them up so that the UCS changes with my named views?
FYI, I have tried the USCFOLLOW command, neither 0 or 1 fix this problem.
4 REPLIES 4
rkmcswain
in reply to: BMATT
When you created the named view, was the UCS saved with it? Or was it set to None?
R.K. McSwain     | CADpanacea | on twitter
nestly2
in reply to: rkmcswain
Right... if you set the UCS before saving the view, the UCS should be oriented as it was when the view was saved.  If you DID NOT reorient the UCS prior to saving the view, just create 3 more custom UCS's and asign them to the matching View (90,180,270) in the View manager.
dbroad
in reply to: BMATT
This may help if the previous responses were insufficient.
Architect, Registered NC, VA, SC, & GA.
BMATT
in reply to: nestly2
That did it, again Nestly - thanks.
”Boost
