Ok, back again - I have my views set up (basically I rotate my drawing 90, 180, 270 and back to 0). When I choose my named view, the drawing turns nicely - but the UCS does not. So when I am working on the new view the horizontal and vertical construction lines are backwards - this is quite frustrating.
I used to just change the UCS with the good old manual 'Z' pick, which worked perfectly, but I am trying to simplify my life (a tiny bit) and just pick the named view - can I set them up so that the UCS changes with my named views?
FYI, I have tried the USCFOLLOW command, neither 0 or 1 fix this problem.
Solved by nestly2. Go to Solution.
Right... if you set the UCS before saving the view, the UCS should be oriented as it was when the view was saved. If you DID NOT reorient the UCS prior to saving the view, just create 3 more custom UCS's and asign them to the matching View (90,180,270) in the View manager.
