AutoCAD Forum
view ports sizing
9 REPLIES 9
Message 1 of 10
rclement
468 Views, 9 Replies
view ports sizing
is there a command or setting that if you add stuff to your model. and then go to paper space that it automatically updates the viewport to include the added drawing stuff
bob
9 REPLIES 9
Message 2 of 10
sthompson1021
in reply to: rclement
I'm not sure I understand what you are asking. If you draw something in model space, it should show up in the viewport in paperspace as soon as you switch to the layout.
Message 3 of 10
Patchy
Not such command for this.
View save in MS then go to PS , unlock the viewport and recall the saved view.
This will mess up your vport scale of course.
Message 4 of 10
nrz13
in reply to: sthompson1021
It should do that unless the layer is frozen in the viewport.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 5 of 10
sthompson1021
in reply to: nrz13
Good point
Message 6 of 10
rclement
actually the viewport sizing. i know it shows up .but sometimes the viewport size is too small and i have to manually size it up .. is there a setting that does this
Message 7 of 10
rclement
i would like to keep the scale intake since i used annotative text and dimensioning
Message 8 of 10
Patchy
There is no command for this, manually stretch the viewport frame is the way to go.
Message 9 of 10
sthompson1021
There is no OOTB command to do this. Don't know if it would be possible with LISP or not. That could get tricky with page setups. I think most people just assign multiple scales to their annotative objects.
Message 10 of 10
rclement
ok just figured i asked. maybe eventually. thank u guys for the input
”Boost
