AutoCAD Forum
vertical multileader, horizontal / centered text
4 REPLIES 4
pwk
2607 Views, 4 Replies
I am using AutoCAD 2014.  I'd like to draw a vertical multi-leader with no horizontal landing.  I would like my text to be displayed horizontally so that it is centered over the vertical multi-leader line.  In properties, in the Leader category, I have tried changing Horizontal Landing and Landing Distance.  In the Text category, I have tried changing Attachment type, rotation, and direction.  No matter what I have changed, I have not been able to achieve my desired result.
Can anyone tell me how to do this?
Thanks in advance,
Paul
4 REPLIES 4
heinsite
in reply to: pwk
If all else fails you might want to consider creating a dynamic block for this.  Your text could be an attribute centered above the line.  And if you want everything to be below instead of above the arrow a simple Flip parameter might do the trick.  Nice thing is you can make it all annotative as well if you like.
Dave.
Dave Hein, P.E.
pendean
in reply to: pwk
The command offers no such feature.
pwk
in reply to: pendean
thank you heinsite and pendean for your help.
I've never created a dynamic block before, but this could be a good way to learn.
Thanks again,
Paul
heinsite
in reply to: pwk
This would be a pretty simple one for you to create too... and a good place to start your dynamic block "career".  Smiley Very Happy
Good luck!
Dave.
Dave Hein, P.E.
”Boost
