Using Autocad 2014 and would like away to put a vertical line at the text where the leader meets it. Is this a setting that I'm missing or might there be a Lisp routine to get it? See the attached jpeg.
Create TWO custom block for Right and Left side text.
And create Two Multi Leader style by changing the Multileader type to Block in Content Tab under ML style.
Then pick the block from Source block.
Thanks for the replies . . . but not sure if that really solves my need. I'd really like to use Multileader and have Autocad place that line no matter the text justification or number of actual text lines.
That's not currently an option. (I used to do that style of callout in manual drafting, since it helped clarify what note was which, but since it's not really practical in CAD we quit doing it.
If it's really critical, you have to either add the vertical line manually, or replace the MLeader with a custiom leader routine as was suggested earlier, or look into creating a routine that would automate the addition of the line to mleader entities.
If it's a 'nice to have', post it in the AUGI wishlist.
