Hi all,
I am currently working with a VBA code developed by someone that allows to insert blocks from excel. I was wondering if it could be modified to change dynamic visual state of block and write in to their tag values too. I am working with 1000+ blocks but all of them have same tag names ( PN_1 & DES_1).
The current code works based on this metheod
RetVal = object.InsertBlock(InsertionPoint, BlockName, Xscale, Yscale, ZScale, RotationAngle)
I have attached the excel and sample blocks with this post.
Kuldeep
Solved by pendean. Go to Solution.
