FATAL ERROR: Unhandled e0434352h Exception at fce8940dh
10/01/2014 at 15:14:30.619
FATAL ERROR: Unhandled e0434352h Exception at fc4c940dh
10/07/2014 at 09:14:51.968
10/07/2014 at 15:15:45.929
FATAL ERROR: Unhandled e0434352h Exception at fc57940dh
10/08/2014 at 09:59:06.985
10/08/2014 at 10:07:35.951
FATAL ERROR: Unhandled Access Violation Reading 0x1900100 Exception at db29d8c5h
10/08/2014 at 13:00:49.264
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at d0d0d1afh
10/08/2014 at 15:13:30.917
FATAL ERROR: Unhandled Access Violation Reading 0x0001 Exception at ddcd783bh
10/09/2014 at 18:53:06.794
FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at dc491b84h
10/10/2014 at 18:41:15.285
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at f5e72843h
10/13/2014 at 09:30:40.781
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at dd106545h
10/13/2014 at 16:16:01.644
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at f5f0783bh
10/13/2014 at 17:16:44.954
FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at d7f01b84h
10/14/2014 at 15:36:20.254
While executing a VBA routine :
FATAL Error : unhandled access violation reading 0x0018.
Hello
With these popular errors, you must first Open your DWG in RECOVER Mode, PURGE (maximum possible), ReSave with an other name (to keep the Original) locally on your hard disk, Quit ACAD, Relaunch ACAD, ReLoad the NEW DWG from local hard disk, ReTest ...
Then have you installed the SP 1 on your ACAD 2014 ?
Patrice BRAUD
Hi braudpat,
Thanks for your reply.
Yes! I have installed the SP1.
The problem is not with the DWG.
The error occurs when I repeatedly launch the same VBA program again and again.
Its works fine for 3 or 4 times and 5th time I get this error.
Post the drawing AND the VBA code so others can try to reproduce the error.
Gaston Nunez
The error occurs with all the VBA programs , if I run it consecutively back to back.
So its not specific to a file or dwg.
Can you anyone define - What the Error Code - FATAL Error : Unhandled Access Reading 0x0018 Exception at ..........
Try any one of the following
1. Clean up the registry.
2. Update Graphics Driver.
Either one of them should solve the 0x0018 Error.
Good Luck.
Hi RANJANSUPERMAN,
If in case you had created Custom profiles then - Clear the Profile / Delete the profiles from registry .
Goto Regedit.exe and find R19.1 under HKEY_CURRENT_USER > Autodesk > AutoCAD
Did you buy the product from a dealer? If so, call them, they have to have product support personal, if not, try to contact some local Professional IT service provider.
As your problem involve VBA code, it's impossible to say what the problem is without seeing the code and or a suspected drawing. Also check the hardware, specially memory modules: memtest86 drivers, etc. It would help if you post the complete platform specs, maybe someone here has the same hardware and could help you to resolve some issues.
Gaston Nunez
The problem was solved by uninstalling the previous versions and cancelling all the new versions of Microsoft .NET Framework
Now, I only have the .NET FRamework 4.6.1 (in my Windows 7 Professional) and it's working fine.
The AutoCAD 2014 (the last version we all have in the company) never crashed anymore.
And one important thing was to deactivate all the grapchis improvements of the Windows, like the deactive all the graphic/visual efffects in Windows properties, likje transparacy and the Windos aero effects.
My computer have Windows 7 Professional
@intel Core i7-2600 CPU @3.40GHz
16 GB RAM
NVIDIA Quadro 600
@mimarsinan_70 wrote:Re: Various FATAL ERROR AutoCAD 2014 messages
16 GB RAM
NVIDIA Quadro 600
@pendean wrote:
What triggers these? Alone they mean nothing at all.
Intel Core i7-2600 CPU @3.40GHz
16 GB RAM
NVIDIA Quadro 600
