AutoCAD Forum
USE OF MIRRTEXT
4 REPLIES 4
4017 Views, 4 Replies
USE OF MIRRTEXT
Hello everyone,
Given the following archtectural Drawing using blocks and attributes below, the four workstations on the front counter were supposed to have been drawn with MIRRTEXT. I tried the same, but couldn't get it in the same as in the drawing. See my attempt on the second picture. I will appreciate if someone could help, please.
Seiji
Original Drawing:
Second Picture - My Attempt but failed:
4 REPLIES 4
dbroad
First, you can't draw anything with MIRRTEXT. It is a setting that affects how text is mirrored.
Second, if you used single line attributes, it looks like you correctly mirrored the blocks with MIRRTEXT set to 0.  To get the 24" LCD line below the QUAD CORE line, you need to have a single multi-line attribute.
You should also note that the assignment given, keeps the mouse right handed, meaning that you should have mirrored the blocks twice.  Unless the instructor is actually checking the DWG files however it would have been much easier to just insert the computer group on the front counter rotated correctly and then copy it.
Architect, Registered NC, VA, SC, & GA.
in reply to: dbroad
dbroad:
I tried the twice mirroring the blocks. And when it came to the order of the text, by double-clicking the block to open the Editor, I forcibly reversed the values of Monitor and Processor opposite as in the picture. It's wrong information but it looks like the one in the given drawing. But, I couldn't push the whole bloc of text to Left Aligned.  Unles you have a further idea, that's as far as I could understand up to here.
Seiji
Ajilal.Vijayan
May be with Dynamic Block rotation action by excluding the text ?
maxim_k
Hi Seiji,
If you un-check "Lock Position" in Mode Section in Attribute Definition dialog (ATTDEF command) during attribute creation, then you will be able to rearrange attribute positions after you mirrored block.
You can also do this in Block Editor Properties palette if you already created block, but in tis case you have to Synchronize already inserted blocks in Block Attribute Manager.
See attached drawing with block with "unlocked" attribute position.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
