Hi all,
I am learning to use Data Extraction (DX) wizard in Autocad and need a little help please.
I have a block which is a pile that has various information. Northing Easting and various values like live load, dead load etc.. I then use DX Wizard to extract this data into a table. Please see image uploaded here:
At the moment a lot of these values (apart from the co-ordinates) are blank. I would like to fill in this information manually. However I do not want to click on each pile individually to insert it into the "Attributes" box. Now if the values for each attribute (say "DEAD_LOAD") was all the same I could just select all the similar blocks and enter the value for all, unfortunately this is not the case.
Is there a way I can see all my blocks (piles) attributes in a table and edit them like a spreadsheet. Like a reverse DX Wizard if it makes sense. I enter the data in a table and it gets put back into the blocks (piles).
Many thanks in advance
Ernest
Solved by Alfred.NESWADBA. Go to Solution.
You can use command _ATTOUT to export the data to a CSV, open then the CSV to edit the data (e.g. using Excel) and after modification use command _ATTIN to get the attributive data back and filled into the block-attributes.
- alfred -
PS: _ATTIN and _ATTOUT are commands from the ExpressTools, so ExpressTools have to be installed with your AutoCAD.
Many thanks Alfred!
That was perfect so simple and worked like a charm!
Best regards
Ernest
Thanks, Alfred, for your ongoing advice to many puzzling questions........
When I see the following dialogue within the data extraction wizard, is this simply another way to accomplish what you described with _ATTOUT & _ATTIN?
Thanks in advance,
LC
Additionally to Ernest's answer: no, it is not. The data from DATAEXTRACTION can not be imported back to update the existiting block-attributes.
The reason for that is that ATTOUT stores the handle (= internal ID of an object in AutoCAD) in the exported file ... so when you import it back the importer (command ATTIN) knows what data belongs to which block-insertion. DATAEXTRACTION does not contain that info, so it's only a one-way ticket.
- alfred -
Thanks to both of you for the insights. I've just begun recently to try my hand at data manipulation/management and have started to obtain some useful results, but you have shown me that there is far more to explore and implement in this area.
Much appreciated,
LC
