I need to mass update attributed blocks in my drawings. The number of different attributed blocks in our drawings range for 40 to over 500. Typically a block would be inserted and the ATTSYNC command would be used to update all the blocks with that block name. This works well for the small updates that normally take place. Recently I had to update the whole library which requires changes to all the blocks in all our drawings.
Is there a way to use the ATTSYNC, but select multiple blocks at once?
Solved by 3wood. Go to Solution.
Typically updates are done as needed, but this was a large change involving all the blocks. I updated visual aspects of teh blocks, their attribute formats and added attributes across our block library, so I need a quick way to update all the blocks within each drawing. The visual changes happen automatically when the block is inserted into the drawing. The attributes take up the most time. If I could do all the blocks at once that would be the easiest and most efficient.
If you have an attribute with the same tag in all your blocks, I guess you could use BATTMAN to change that value across the board. Then you would need some type of routine to Open, change in BATTMAN, Save, Close, every drawing in a folder. There are some out there which could do that from Windows.
Thanks, I've seen some of those, but I have 28 attributes per block. The formatting can be different for each attribute based on the equipment and usage. Using BATTMAN in the past caused a lot of problems and reduced efficiency.
