Not sure if this exists but it would be useful to have...
From time to time we get unhandled exception errors, some of them can be fixed after a bit of research but some of them can be a real problem trying to troubleshoot.
Does anyone know if there is a database anywhere that has the most common unhandled errors documented. Something like a unhandled exception knowledgebase. If you do, could you send me a link please, otherwise we will still have to trust Google Search and the Forums to resolve these issues.
Duncan
Other than the KB, Google will be your best bet. Many in the Forums use Google instead of the built in search engine to find information thay need.
http://usa.autodesk.com/adsk/servlet/ps/kb/autoindex?siteID=123112&id=2334144&linkID=9240617
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Charles,
I thought that might be the case... thanks for your input! I'm curious if anyone else might have any other suggestions as these issues are such a pain to troubleshoot.
P.S - I was kind of hoping someone from Autodesk would have thought this is a good idea and setup a knowledgebase purely for these issues or at least document the most common issues and fixes.
Duncan
here is one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21989963&linkID=9240617
DarrenP
if you happen to get on a laptop with Nvidia optimus technlogy
DarrenP
