AutoCAD 2013/2014/2015
Member
0 Kudos
Post 1 of 5
Unhandled Exception 2 (Access Violation Reading 0xd5f0d560) at address DB0D3C34h
865 Views, 4 Replies
04-09-2013 01:58 PM
I have 5 AutoCAD 2013 users that receive Unhandled Exception 2 errors when closing AutoCAD files.  All users are on Windows 7 64-bit machines, but amount of RAM varies.  Three machines have 4GB of RAM, one has 8GB and one has 12GB.  AutoCAD is 2013, SP1.1 64-bit.  All machines are Dells either Optiplex 980 with Nvidia GEForce GT330 card or Optiples 990 with AMD Radeon HD 660Series video card.
We have updated the video drivers on both machine types to the latest version.  The users state that the errors occur on newly created files as well as files that they share between themselves, but only occurs when closing files.  AutoCAD opens with out errors.
I've attached a Word document with the series of errors that are created when closing a drawing.  Would appreciate any ideas to help resolve the issue.
463 Kudos
Post 2 of 5
Re: Unhandled Exception 2 (Access Violation Reading 0xd5f0d560) at address DB0D3
04-10-2013 05:40 AM in reply to: csu-it-tech
"I have 5 AutoCAD 2013 users that receive Unhandled Exception 2 errors when closing AutoCAD files"
Do you also have other 2013 installs configured the same that work just fine?
"The users state that the errors occur on newly created files as well as files that they share between themselves"
Is the same dwt or dwt's being used to create these new drawings?
Has a recent _Audit been ran on the dwt's being used to create the drawings?
Are the 5 users using the same arg profile?
What happens if a the vanilla profile is loaded and a user attempts to exit with this profile loaded?
"but only occurs when closing files"
Can the files be saved before the crash?
Does it seem to matter if a file is saved locally or to network?
Are these new installs or did they work until recently?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Member
0 Kudos
Post 3 of 5
04-10-2013 06:09 AM in reply to: Jay_B
Jay:
I'll have to check with the users on your questions about the dwt file and the audit.  Each user has their own arg profile.  One user has carried over his customizations since AutoCAD 2009.  I will also check on if the errors occur when saving a file.  The reports I've received are when closing AutoCAD.
All files are saved to a network drive.  AutoCAD 2013 was installed over a year ago on these machines.  The reported issues start approximately 3 months ago.  We have tried various fixes based on suggestions found on the AutoCAD forums, but nothing has worked so far.
Will post more when I have more information from the users.
Member
0 Kudos
Post 4 of 5
04-10-2013 08:02 AM in reply to: Jay_B
Jay:
Here are the user replys:
1.  Everyone in this section gets the unhandled exception errors.  There are other installs in different sections that work just fine.
2.  Newly created files do not have the error, but if a file that has the error is open at the same time the new file is open, the new file can obtain the error.  If the new file is closed without opening a file with the error, the new file does not get the error.
3.  A recent _Audit has been runo on the dwt files including purging and -purge.  It was also used and all unreferenced Xrefs were deleted.
4.  We do not use and arg profile.
5.  In this section a new user to AutoCAD on a machine will not have the problem initially, but will develop the symptoms after 6 - 8 weeks of using this sections drawings.  A new user to a section without the issue does not develop the issue.  Files are not shared between the sections.
6.  FIles can be saved before the crash.  It does not matter if the files are saved locally or to the network.
7.  New installs work without issue for 6 - 8 weeks, but the problem slowly creeps into the existing files.  AutoCAD is installed individually to the machines.
Please let me know if you need anything else.
New Member
0 Kudos
Post 5 of 5
09-05-2014 01:53 PM in reply to: csu-it-tech
This is exactly the same thing that happens at our office when closing some files. Usually there are 1 to 6 error messages that popup after autocad has closed. Is this an object enabler problem? Has anyone found a reliable solution to this issue?
