AutoCAD 2013/2014/2015
0 Kudos
Post 1 of 6
Unhandled Access Violation reading 0xffffffff exception at e14572a7h
2272 Views, 5 Replies
02-14-2013 12:06 AM
Hi Everyone,
We're trying to elete an object with a constrain on it in ourdrawing. Problem is, when we try to either delete the object or remove the constraint on it, our AutoCAD 2013 crashes with the error in the subject. Additional detail is that the file was created in a lower version, I'm hazy on it but I think it was created on AutoCAD 2011.
Has anyone else encountered this problem? Thanks. :smileyhappy:
474 Kudos
Post 2 of 6
Re: Unhandled Access Violation reading 0xffffffff exception at e14572a7h
02-14-2013 04:59 AM in reply to: ronane
Is this a crash you can repeat in any new empty drawing, or does this only happen in a particular drawing?
0 Kudos
Post 3 of 6
02-14-2013 05:18 PM in reply to: rkmcswain
Hi rkmcswain,
The error is only for a specific drawing.
263 Kudos
Post 4 of 6
02-14-2013 11:36 PM in reply to: ronane
Hello
Could you open your DWG in RECOVERY Mode and then Re-Save it ...
Have you yet the same problem ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
0 Kudos
Post 5 of 6
02-14-2013 11:53 PM in reply to: braudpat
Hi Patrice,
Thanks for the reply. We can't open it in RECOVER, it just crashes. It just says  "problems were were detected. recommend that you save your work and restart program."
263 Kudos
Post 6 of 6
02-15-2013 02:48 AM in reply to: ronane
Hello
Aie, Aie, your DWG seems very damaged !
An other idea : from a blank DWG with correct Units
Try to insert it at 0,0 - Rotation = 0 - Scale = 1 - In exploded mode
If OK, please try immediateley an AUDIT
Good Luck, Bye, Patrice
