AutoCAD 2013/2014/2015
Distinguished Contributor
dmmeehan
Message 11 of 15 (856 Views)
Re: Unable to save change to right click customization
10-04-2012 05:13 AM in reply to: ddavid
I just tried turning off the Autocomplete "suggestion list" and that seems to force right click enter to actually enter instead of having to press it twice. Right click on the command line and choose the autocomplete flyout to change.
dmmeehan
Message 12 of 15 (855 Views)
10-04-2012 05:15 AM in reply to: OrionHE
Try turning off the autocomplete suggestions list
Active Member
OrionHE
Message 13 of 15 (841 Views)
10-04-2012 01:25 PM in reply to: dmmeehan
Thank you for understanding my problem and resolving it.  I unchecked "Auto-Append" and my flow is back.  Thank you again!
Member
gneuhaus
Message 14 of 15 (636 Views)
04-02-2013 06:40 AM in reply to: OrionHE
I got to the end of this string and I was disappointed to see no final answer to the question.  So I am posting this answer.  If you turn on "Turn on time-sensitive right-click:", it will lock the Default Mode, Edit Mode and Command Mode to whatever you set it to be, see attached.  To make changes to the settings, uncheck "Turn on time-sensitive right-click:", make necessary changes then re-check "Turn on time-sensitive right-click:".
New Member
marvtm_art
Message 15 of 15 (118 Views)
07-02-2014 05:40 PM in reply to: gneuhaus
Gneuhaus you are correct however the actual problem is that of requiring a single click to progress a command:
(i.e/e.g: Press "L" then one click starts the LINE command)
Hopefully this becomes the final of this thread:
dmmeehan (/OrionHE) solution is the key:
Turn off autocomplete (you can use the settings "spanner" for your command line in AutoCAD2015) and under "InputSettings" turn it off.
This allows the first right click to become "ENTER" instead of selecting the first autocomplete and requiring a second click (or third)
