Having purchased a Mac to do my Masters in Architecture I have moved away from using AutoCAD on PC. For some reason I am not able to zoom or pan the contents of my viewport when on a layout?? I know that if I select the viewport making sure its unlocked I should be able to zoom in, out or even pan my drawing which technicaly is modelspace to suit my layout, but instead when I zoom or pan it zooms or pans the layout. So fustrating!! Anyone have any solutions??
Solved by pendean. Go to Solution.
Just double check with you.
If you select your viewport then ctrl+1
in the porperties table > Misc > Display locked = yes or no?
You have the same problem in all drawing or only one drawing?
If for only one drawing, suggest you "audit" it then try again.
If it still not work. just make a new drawing on all layers copy every model space to model space and paper space to paperspace.
When I am in Paper space and double click the viewport it brings me full screen into Model space. I want to be in model space within the viewport to move the image in the VP, how do I keep it from going full-screen MS?
Also, My properties menu doesn't have many basic commands listed. I have to use workarounds to access commands.\ and finally my helpdesk space will not display properly the top 2 inches is out of view and the text runs off my screen so I cannot get the instructions I need.
Thanks very much for your advice from 6 years ago 🙂
I had exactly the same problem, viewport display was set to locked, this resolved it instantly.
I'm on a PC so this isn't a MAC issue, it's a format setting (within the file I was editing in this instance) issue.
