AutoCAD 2013/2014/2015
0 Kudos
Post 1 of 11
Unable to open dwg created in AutoCAD LT 2010 dwg in AutoCAD 2013
668 Views, 10 Replies
02-06-2013 12:00 AM
HI,
The dwg is created in AutoCAD LT 2013. i am unble to open the dwg in AutoCAD 2013. Tried recover, wblocked it. Still does not work. Service pack is applied for AutoCAD 2013.
1,219 Kudos
Post 2 of 11
Re: Unable to open dwg created in AutoCAD LT 2010 dwg in AutoCAD 2013
02-06-2013 12:20 AM in reply to: jkkagalkar
and can you open it now with LT again (whatever version you mean as the header says LT2010 and in the message text you wrote LT2013)?
- alfred -
Alfred NESWADBA
0 Kudos
Post 3 of 11
02-06-2013 12:25 AM in reply to: jkkagalkar
Yes , the dwg file can be opened in AutoCAD LT 2010 again.but not in AutoCAD 2013.
1,219 Kudos
Post 4 of 11
02-06-2013 12:31 AM in reply to: jkkagalkar
Two options I see now:
  • a) open the drawing in LT2010 and save it back to DWG2007 or DWG2004 format. Then try to open this file in 2013
  • b) load the drawing in LT2010, then WBLOCK just the modelspace-entities to a new drawing, can you open this new drawing in 2013?
If all fails can you upload that drawing?
- alfred -
Alfred NESWADBA
0 Kudos
Post 5 of 11
02-06-2013 01:32 AM in reply to: jkkagalkar
The dwg has been saved in 2004/2007 format, but still it does not open in AutoCAD 2013. I am attaching the file for your reference.
1,219 Kudos
Post 6 of 11
02-06-2013 01:57 AM in reply to: jkkagalkar
First yes, I can reproduce the problem with 2013 (x64 German SP1.1).
when I open your drawing with AutoCAD 2012 I get the message that this file is not created by an Autodesk product. That sounds for me like anything modifies the DWG that is not AutoCAD (before you uploaded it here).
Do you have any applications running on top of AutoCAD?
I guess you have conflicts with AEC-objects in the drawing. So what I did: I opened your drawing in 2012, then run command _-EXPORTTOAUTOCAD ==> and that drawing can now be opened in 2013.
I'm sorry not to know it that command is available in LT. ;(
Please find the converted drawing attached.
- alfred -
Alfred NESWADBA
0 Kudos
Post 7 of 11
02-06-2013 03:04 AM in reply to: jkkagalkar
That's a workaround.. if I dont have AutoCAD 2012., what is the solution? Thanks in advance
1,219 Kudos
Post 8 of 11
02-06-2013 03:10 AM in reply to: jkkagalkar
You should verify where you got the drawing from (or items you used in the drawing) as there are AEC-objects in the drawing that have to be cleaned up to plain AutoCAD-geometry types.
If the command _-EXPORTTOAUTOCAD does not exist in your LT you can't do anything else. I guess you got this drawing from someone usign ACA or MEP, and this user should then use the command before sending the data to you.
- alfred -
Alfred NESWADBA
0 Kudos
Post 9 of 11
02-06-2013 04:24 AM in reply to: jkkagalkar
Yes, -EXPORTTOAUTOCAD option is available in AutoCAD LT which will resolve the issue. Thanks again..
New Member
0 Kudos
Post 10 of 11
01-13-2015 08:31 AM in reply to: jkkagalkar
hi. i'm using cad 2013 and i wanted to open a file. Itwas created on cad 2010. But i wont open.
