AutoCAD Forum
Unable to “copy” or “export” from the attached dwg file,
3 REPLIES 3
JamaL9722060
365 Views, 3 Replies
I couldn’t figure out what the “copy” or “export” are not working when applied in the attached dwg file
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
3 REPLIES 3
rkmcswain
in reply to: JamaL9722060
Delete both layouts, then try again.
R.K. McSwain     | CADpanacea | on twitter
pendean
I got a proxy notice when I opened your "export to a layout" file: You saved your file down to R2010 but you use 2013? So you created a bunch of Proxy Objects that can't be copied in lower versions and probably create the issues that way.
I cleared all the proxy objects and I can now copy and export with no issues in 2013/2014/2015. There are freeware and lisps out there to help you remove them.
JamaL9722060
in reply to: pendean
Many thanks guys for the help.
Deleting the layouts solve the issue
Best
Jamal
Jamal Numan
”Boost
