I created a drawing in model. Then some how messed up and have two images showing up in landscape view via viewport. So it seems that their are two viewport windows working? How do I get rid of one?
If there are multiple viewports, you can use CTRL+R to toggle between them.
You should be able to select them indivdually in PaperSpace unless the Viewports layer is Off/Frozen, in which case just turn on the viewports layer temporarily so you can select them.
Hi, If you are saying you have two viewports in model space and you only want one, type VIEWPORTS at the command line and select single in the popup box.
I can't get the viewport tab to become active while viewing in a landscape tab. It only become active when view in model. I right clicked the tab to make sure it was turn on and it is.
This is what my teacher said to do, didn't work. Tired of asking this guy for help and getting answers that don'e work.
Hi, I don't quite understand what you are asking. Are you having a problem switching from paperspace to model space in a layout?
