I am not a user of autocad, is there a way to import .pat files or .jpg files created in photoshop into autocad to be used as hatch patterns?
If not can export sketchup files in a format that can be imported into autocad to be used as hatch patterns?
Solved by scot-65. Go to Solution.
Solved by Patchy. Go to Solution.
Place PAT files in a folder that has a support path declared (command OPTIONS).
Only one pattern definition allowed inside a PAT file (exception is ACAD.pat).
command BHATCH and select the ellipse button [...] next to the Pattern drop down.
Tab to Custom.
Make selection.
If pattern is erroring out, then code structure is not correct. Most likely it is the header
of the pattern that is not following the rules. Open ACAD.pat with an ASCII editor and
look at how the headers are structured and try to replicate. If not mistaken, the header
and file name must match (and no spaces or escape-type characters in file/pattern name).
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Though it may not work for every situation, you can have two hatches associative to the same boundary. So a true color solid behind say a brick or plank pattern is a simple way to fake a surface texture. Unlike the superhatch the composite hatch can be easily edited by adding vertexes to the boundary or adjusting hatch properties.
@Tommy2shoes wrote:
Though it may not work for every situation, you can have two hatches associative to the same boundary. So a true color solid behind say a brick or plank pattern is a simple way to fake a surface texture. Unlike the superhatch the composite hatch can be easily edited ....
That's still a far cry from using something like a photoshop image as a hatch pattern [I suspect the Superhatch suggestion is the only way to do that]. But if what you suggest works for a given user, in newer versions of AutoCAD you can do that with one pattern, because there's a background color option:
Hi @Tommy2shoes,
Did you get a solution to your hatch question? If so, please mark a post or posts as Accepted Solution. If not, Let me know where you are in the process and I can try to offer further suggestions.
What brought me into this discussion was a search for something better than Super Hatch to wallpaper 2D wall elevations. Being able to adjust a hatch pattern origin, scale & rotation etc. after creation is better than not being able to. I will take another look at using Materials and View Styles.
Hi @Tommy2shoes,
Yes, mapping materials is probably the better way to pursue this. Hatches are designed to handle linework.
To get the attached PDF I installed the monitor drivers which the IT department neglected to do. Much improvement in output to PDF even using realistic view style. Your standard wallpaper material is in model space on a thickened polyline object. The remaining room images are just that, clipped images also placed in model space. The text and vector objects need to be in paper space.
