I am using the Autocad 2014. In the top right side of the Autcad2014 I can see the following features.
Search, Sign in , Live Updates and Help.
I want to hide those features permanently. I have tried the following steps in the registry to hide Infocenter mentioned in various forums, but still I can see those features.
1. Modified the InfoCenterOn to '0'
2. EnableCommunication.. to '0'
Is there any other way or configuration files which I need to modify to turn off those features.
Kannan
Make sure you are changing the correct value in the correct key.
I just tested this and it does work for AutoCAD 2014. (Your subject says 2013, but the body of your message says 2014??) I am 95% sure the same process works for 2013, 2012, etc.
Close all sessions of AutoCAD
Go to this location in REGEDIT:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409\InfoCenter (The R19.1 and the ACAD-D001:409 sections may be slightly different on your version)
Set the value of "InfoCenterOn" to 0.
Restart AutoCAD.
AFTER:
Thanks, it works. Hopefully this will solve some of my troubles.
The additional services are also not starting up any more.
Hello from France
You can try something else ! You must be Local Admin of your PC
<Humour ON>
--> Your ACAD will be "very" quiet with the Web & Internet !!
<Humour OFF>
Into : C:\Program Files\Common Files\Autodesk Shared
and into : C:\Program Files\Common Files\Autodesk Shared\WSCommCntr?\lib
Please check any folder : WSCommCntr?
Rename any "WSCommCntr?.exe" to something like "WSCommCntr?.ex_sav"
Re-Run ACAD , any improvment ?
Bye, Pat
Patrice BRAUD
Try to copy this LISP routine to command line. It is a toogle switch the InfoCenter ON or OFF
(if (= (vl-registry-read (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\InfoCenter\\") "InfoCenterOn") 0)
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\InfoCenter\\") "InfoCenterOn" 1)
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\InfoCenter\\") "InfoCenterOn" 0)
